Object Properties for Text is geezed
Latest build, working on file originated in previous build.
Attempted to change type face.
Works fine here in previous job with text.
i have 35 files done before the new build I installed this morning. The text in about 10 I had to tweak for my design meeting this aft all work fine. In fact, if I change fonts it updates while still selected and not once I de-select to update like before.
An aside, I have to cut ( or copy, I don’t remember ) to adjust alinement of old text. The alinement option is not available from object properties text box. Not that much of a deal at this point, but it would be nice in some instances to change it there instead of in a new text insert box.
Randy
Hmmm.
Thanks for sharing your experience. Now I’m wondering if it’s because I running on Yosemite….
John B.
I cannot duplicate this with Rhinoceros version: 5.0 Wenatchee 2014-10-14 (5A552) and OS X version: Version 10.10 (Build 14A386a). Please post your Rhino info from the About Rhinoceros dialog.
System Version:OS X 10.10 (14A388b) Kernel Version:Darwin 14.0.0
I wasn’t specific enough about what I want. Please click the More Info… button on the About Rhinoceros dialog and post the result when you click the Copy to clipboard button on the Rhino Information dialog.
Software information
Software versions Rhinoceros version: 5.0 Wenatchee 2014-10-14 (5A552) IronPython version: 5.1.2014.1006 Language: en-US (MacOS default) OS X version: Version 10.10 (Build 14A388b)
Plug-ins /Users/xxxxxxxxxxxxxx/Library/ColorPickers/RCWebColorPicker.colorPicker/Contents/MacOS/RCWebColorPicker
Third party kernel extensions org.virtualbox.kext.VBoxDrv (4.1.22) org.virtualbox.kext.VBoxUSB (4.1.22)
Hardware information
Computer hardware Hardware model: MacBookPro5,5 Processor: Intel Core2 Duo CPU P8700 @ 2.53GHz Memory: 8 GB Architecture: Intel 64 bit
Video hardware Graphics: NVIDIA GeForce 9400M 256 MB Memory: 256 MB Screen size: 1280 x 800 Displays: Color LCD
USB devices Apple Inc.: Built-in iSight Apple: Internal Memory Card Reader Apple Inc.: Apple Internal Keyboard / Trackpad Apple Computer, Inc.: IR Receiver Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices None
OpenGL information
OpenGL software OpenGL version: 2.1 NVIDIA-10.0.19 310.90.10.05b12 Render version: 2.1 Shading language: 1.20 Maximum texture size: 8192 x 8192 Z-buffer depth: 24 bits Maximum viewport size: 8192 x 8192
Implementation settings Use texture compression: Yes
Appearance settings Antialiasing: 8x Mip map filtering: None Anisotropic filtering: High
I don’t see any obvious cause here. You are running VirtualBox, but I don’t see how that could be causing a problem.
Starting from a new modeling window, can you describe in detail what I should do to recreate this problem?
Can’t recreate from new, so far - will try to find which file this happened with and try to recreate there.
