Hi, 2 questions in the new category I cant find the answer to. If someone can point to where this info is located, it will help to avoid newb questions from me.
I would like to have my viewports be set to shaded as default on startup… Is there a setting for this?
My second question was regarding setting surface color and the parent/child relationship. I would like to override this. The scenario would be create a box and explode it to surfaces, then I would like to assign a different color to the surfaces, then join them back to a solid, and retain the individual surface color assignments. (Or better yet, do a sub selection on each surface of a box and assign the color there, without exploding the solid.
You will have to create a template and set this up in your template file and save it. Template files are just Rhino files with some individual customization; layers, viewports, display modes, etc. See the Help under “New” for how to create and save a template file.
You cannot, unfortunately. Joined solids can only have one object color.
Thanks Pascal,
Yeah, the idea was to have the ability to assign “colors” to individual faces, even on a joined, closed solid. I havnt gotten into materials yet. This may be whats needed.
Well… there is testPerFaceMaterial. This is a clunky, limited, unsupported (you don’t get to complain) , undocumented command that may help for now.
You need to have an object with a material assigned. You select this as the source object, then click on one or more faces on other objects to paint those faces with the first object’s material.
