I’m revisiting an attempt to get this function to multi thread, since we have several hundred curves and only one surface.
Could somebody give me a hint why this code doesn’t work? (neither multi thread or standard)
Thanks
import ghpythonlib.components as ghcomp
import ghpythonlib.parallel
#custom function that is executed by parallel.run
def offset_on_surface(curves):
result= ghcomp.OffsetonSrf(curves, surface, distance)
if result: return result.curves
def slice_at_angle(plane):
result = ghcomp.BrepXPlane(brep, plane)
if parallel:
slices = ghpythonlib.parallel.run(slice_at_angle, planes, True)
else:
slices = ghcomp.BrepXPlane(brep, planes).curves
So far I din’t had any return/ouput/error message with this, that’s why I asked here.
And it was exactly that “slice” example I used as basis for my offset.
I just tried djordje’s tip with the return and input order, now it works.
By the way, wouldn’t it be helpful to have a library of all “obvious” functions which really could benefit of multi-threading somewhere?
If everybody “translates” one of them, we could have all of them done in a week!?
Keep in mind that Rhino is not thread safe. You can create worker thread. But they cannot do anything with Rhino or the Rhino document. Treads can manipulate geometry as long as it is your own copy (and not in the document). Also, don’t share objects between threads…
Even then, my experience is that spurious crashes can still occur if you’re not careful. I ended up parallelising a certain algorithm we use a lot in C++ after the C# implementation gave weird intermittent crashes.
I also had often crashes with ghpythonlib.parallel. Have just tried replicating the code from this topic, and experienced the same crash when parallel is used.
