Hi!
I am using this command to make the main views of some interiors.
In Layout, I am applying Leaders. These leaders use a formula for ObjectName. But my newly generated objects (contours) from the “make2d” command do not have the name in them. It’s just blank.
Can you please implement (WISH), in the MAKE2D command, an option that will give to the newly generated 2D objects (contours) their original object’s properties (such as Name or Linetype).
Thus, the new lines will have in their name (in properties)… the names of the objects they belong to (the original lines, surfaces or solids).
Thank you,
T.
