I can’t seem to figure out why, when in macro editor, with macro editor highlighted, or in notes with notes pane highlighted, that when I type it goes straight to the command line.
I just updated Rhino, to the most recent release. I recall seeing that rhino was up to date earlier today. I downloaded and installed a plug-in, GenBolt today too. I believe I did the Rhino update afterwards.
Anyways, I cant edit text inside either macroeditor or notes inside rhino.
Is there a setting, to set some kinda priority for text or something? I cant find anything in any options under keyboard, or shortcuts or anything.
I did find a thread about why single letter keys cannot be hotkeyed, because programs like rhino with commands cant tell the difference. Which will be useful when I get my keyboard soon, with programmable multiplier keys. Now I know why single keys cant be used. I’m a use multiplier keys, and the f1-12’s and stick to them. Then I’ll have 84 commands/toolbar popups/macros, and be somewhat easy to remember them with a cheatsheet.
Anywho, is there a setting or a bug in the latest release???
Update, Calculator is working normally, with numbers from above letters and keypad.
Webbrowser working fine as well. Still no notes or macro editor.
Update: I restarted my computer. I don’t remember if I did after the update. The macro editor was the same. Then I decided to do it in windows notepad. I copied from windows notepad, and ran the command. Then I deleted it. Then typing in macro editor worked. So I decided to play. Clicked in viewport, etc…
It works sometimes when I click in the macro editor pane and type, and sometimes it doesn’t. For it to work, you need to have some text in the macro editor.
