Isolate Objects?
Is there an Isolate Objects feature or script that works for Rhino for Mac? It would be really useful to add this to the main Rhino UI.
thanks,
David
This will be added to RH6 but doesn’t help you now.
There are several scripts floating around for this but most are in RhinoScript I guess and not for Rhino for Mac.
This one by @defterGoose is in python and you should be able to run that - but I haven’t personally checked it for its functionality.
Else, here is CS code by @dale if you are really feeling adventurous:
SampleCsIsolate.cs
SampleCsUnisolate.cs
