I’m having trouble installing a python extension. I’ve tried PIP installing to both the following directories and they install correctly, the files are there, but Rhino’s Python does not want to import the library:
Message: cannot import _simplecoremidi from simplecoremidi
Traceback:
line 1, in , "/Applications/RhinoWIP.app/Contents/Resources/ManagedPlugIns/RhinoDLR_Python.rhp/Lib/simplecoremidi/core.py"
line 1, in , "/Applications/RhinoWIP.app/Contents/Resources/ManagedPlugIns/RhinoDLR_Python.rhp/Lib/simplecoremidi/init.py"
line 1, in , “/Users/Alex/Downloads/MIDI Research/test.py”
Thanks for your response. Yes I am using Atom thanks to Steve’s recommendation. I’ll try the ctr+option+s to configure the path.
Hmm, that Library says that it runs on Python 2.7, I was assuming that it would work on Rhino’s Iron Python. I got it to work yesterday on Maya’s python by simply copy pasting it into the correct directory. I was just a few .PY files.
Here is the link to the package. It’s pretty simple, but maybe you’re right, it’s wrapping something:
I added the directory to Atom with ctr+option+s but that didn’t help. The module has 2 versions. 1 is for Python 2.7 and the other is 3.0. Neither work. I’m stumped. This is the error:
Traceback:
line 1, in , “/Applications/RhinoWIP.app/Contents/Resources/ManagedPlugIns/RhinoDLR_Python.rhp/Lib/simplecoremidi/core.py”
line 1, in , “/Applications/RhinoWIP.app/Contents/Resources/ManagedPlugIns/RhinoDLR_Python.rhp/Lib/simplecoremidi/init.py”
line 1, in , “/Users/Alex/Downloads/Simple Core Midi - OSX/simplecoremidi-master/simplecoremidi/examples/play_a_scale.py”
Is it because the module wraps a C code perhaps? Any help would be greatly appreciated.
