Hello!
I would like to make an individual python script (witch I can invoke from command line without opening the Rhino). I’m using IntelliJ, and IronPython, for this, I added the RhinoCommon.dll by this way:
sys.path.append(r"C:\Program Files\Rhinoceros 5 (64-bit)\System")
clr.AddReferenceToFile("RhinoCommon.dll")
It work fine (I use more of the Rhino methods) until I call the Rhino.Geometry.Brep.CreateFromLoft method. It throw the next error:
Unhandled Exception: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at UnsafeNativeMethods.RHC_RhinoSdkLoft(IntPtr pCurves, Point3d start_point, Point3d end_point, Int32 loft_type, Int32 simplify_method, Int32 rebuild_point_count, Double refit_tolerance, Boolean bClosed, IntPtr pBreps)
at Rhino.Geometry.Brep.LoftHelper(IEnumerable1 curves, Point3d start, Point3d end, LoftType loftType, Int32 simplifyMethod, Int32 rebuildCount, Double refitTol, Boolean closed) at Rhino.Geometry.Brep.CreateFromLoft(IEnumerable
1 curves, Point3d start, Point3d end, LoftType loftType, Boolean closed)
at Microsoft.Scripting.Interpreter.FuncCallInstruction6.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.LightLambda.Run8[T0,T1,T2,T3,T4,T5,T6,T7,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6, T7 arg7) at System.Dynamic.UpdateDelegates.UpdateAndExecute7[T0,T1,T2,T3,T4,T5,T6,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3, T4 arg4, T5 arg5, T6 arg6) at Microsoft.Scripting.Interpreter.FuncCallInstruction
10.Run(InterpretedFrame frame)
at IronPython.Compiler.Ast.CallExpression.Invoke5Instruction.Run(InterpretedFrame frame)
at IronPython.Compiler.PythonCallTargets.OriginalCallTarget7(PythonFunction function, Object arg0, Object arg1, Object arg2, Object arg3, Object arg4, Object arg5, Object arg6)
at IronPython.Runtime.FunctionCaller1.Default6Call1(CallSite site, CodeContext context, Object func, T0 arg0) at System.Dynamic.UpdateDelegates.UpdateAndExecute3[T0,T1,T2,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2) at Microsoft.Scripting.Interpreter.FuncCallInstruction
at Microsoft.Scripting.Interpreter.LightLambda.Run4[T0,T1,T2,T3,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3)
at IronPython.Compiler.Ast.CallExpression.Invoke1Instruction.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
at IronPython.Compiler.PythonCallTargets.OriginalCallTarget1(PythonFunction function, Object arg0)
at IronPython.Runtime.FunctionCaller`1.Call1(CallSite site, CodeContext context, Object func, T0 arg0)
at IronPython.Runtime.Method.MethodBinding.SelfTarget(CallSite site, CodeContext context, Object target)
at IronPython.Compiler.Ast.CallExpression.Invoke0Instruction.Run(InterpretedFrame frame)
and so on,…
I would like to make a script to generate remotely some meshes (exported to .obj, or something else). I tested my code inside the Rhino, it works (I don’t use rhinoscriptsyntax), but It throws the upper error outside the Rhino.
What should be the problem?
I hope you can help me!
