It would be nice if you could add multiple textures at once to the texture pallet in rhino. That way you could load up all your textures in one go and then assign them to materials as you build them.
You can do this if you dock the Texture palette and then drag and drop multiple files into the white texture thumbnail area.
good to know. That’ll save some time. Any reason you can shift click and select a bunch?
I bet you meant ‘can’t’ when using the file browser. This was probably just overlooked by the developers and I’ll file it. You also can’t drag and drop multiple image files to the viewport to add them to materials or the texture palette although this works with a single image file. I can file that too.
yeah that was a typo the “'t” changes the whole thing.
