I have heard that Rhino can import these files.
Is this true?
Brian
Is this true?
Brian
HI Brian,
Out-of-the-box Rhino will not import .dcm files. But it looks like the Dental Shaper plug-in for Rhino will provide this functionality.
http://www.sum3ddental.com/prodotti/Dental_Shaper/BRIEFLY/
Also, if you Google a bit, you can find other tools that convert .dcm files into .stl files, which can be imported by Rhino.
– Dale
Thanks! I’ll look into this…
Brian Smyth MASc, P. Eng.
Lead Experimental Engineer
School of Sustainable Design Engineering
Dalton Hall Room 513
550 University Avenue
Charlottetown, PEI C1A 4P3
bsmyth@upei.ca mailto:heartz@upei.ca
www.upei.ca/engineering http://www.upei.ca/science/engineering
Statement of Confidentiality
This message (including attachments) may contain confidential or privileged information intended for a specific individual or organization. If you have received this communication in error, please notify the sender immediately. If you are not the intended recipient, you are not authorized to use, disclose, distribute, copy, print or rely on this email, and should promptly delete this email from your entire computer system.
Hi Brian,
There is a converter that can convert .DCM files to .STL, but it only supports DCM files coming from 3Shape (http://www.datakit.com/en/cross_manager.php).
Are your files coming from 3Shape or from another source?
Hi Felix,
Our files are coming from a CT machine.
Brian
Ok, so i think that the software that i mentioned will not help you. It only supports dcm files coming from 3Shape dental scanners.
Thanks Anyway!
