Help is needed!
Painted using a contour of an object (“Twisting” tool).
It seems everything is OK.
But when approaching the edge, you see gaps.
How to fix them?
Help is needed!
How to fix them?
Hi Russlav - this can be cleaned up by setting a more accurate display mesh - please see
http://wiki.mcneel.com/rhino/meshfaq
Hi Russlav- you will always be able to zoom in enough to see gaps at some level. The best control is the ‘Maximum distance edge to surface’ - set that to .1 or .01 and see how it goes.
The gaps can not be removed completely?
Correct - but that is because the render mesh is not the surface:
http://wiki.mcneel.com/rhino/meshfaqdetails
"Although Rhino is a NURBS surface modeler, it uses polygon meshes created from those surfaces for visualization purposes. So what you see on the screen when the model is shaded is a special, invisible polygon mesh (the render mesh) that is attached to the actual NURBS surface.
Why? For quick shading and rendering. While a mesh has the advantages of shading speed and adjustability, there is a disadvantage. The render mesh is always an approximation of the surface, so there are almost always gaps between the faceted render mesh and the actual smooth surface."
There is no physical gaps. Just visual.
Thank you!
