I would like to write a python script that prints a pdf without opening the printing window.
I just need two variable settings: 1. size of the paper; 2. View/Window/Set
Maybe its possible to use something like:
rs.command (_-print “save as pdf, with colors, size: A0, and all needed print settings”)
But how to insert all the settings?
I am a python newbie btw
Thanks for your help!
dale
(Dale Fugier)
2
Its not clear to me that the Print command can be fully scripted. For example, if you do this:
_-Print _Setup _Destination _Printer "Microsoft Print to PDF" _Enter _Enter _Go
You will see a file save dialog box when you should be prompted for the name of the file to create.
http://mcneel.myjetbrains.com/youtrack/issue/RH-34321
The reset of the setup should be scriptable, though.
