i’m 100% sure there’s a better approach to this than the following but…
your question made me want to script a method which i’ve used to draw this type of curve onsite before…
that being… put a circular object (bucket) on the ground… hold a pencil at desired length along a string (electrical cord) then draw the curve… as the string goes around the bucket, the radius constantly shortens…
(well the centerpoint shifts too… so not what your asking it to do anyway)
import math
def bucket_and_string():
inner = rs.GetReal('Radius of inner circle', 10)
if not inner: return
start = rs.GetReal('Starting radius', 50)
if not start: return
rs.AddCircle((0, 0, 0), inner)
line = rs.AddLine((inner, 0, 0), (inner, start, 0))
startlength = rs.CurveLength(line)
points = [(inner, start, 0)]
for i in range(1, 72):
angle = math.radians(i * 5)
arclength = inner * angle
if startlength - arclength < 0:
break
rotatedline = rs.RotateObject(line, (0, 0, 0), i * 5, None, True)
rs.ExtendCurveLength(rotatedline, 0, 1, -arclength)
pt = rs.CurveEndPoint(rotatedline)
points.append(pt)
rs.AddInterpCurve(points)
bucket_and_string()
EDIT:
here’s one which will rotate a radius 5º and shorten it each time.
# parameters
a = 50 # starting radius
b = -1 # increment in which the radius will shrink (or grow) per rotation
line = rs.AddLine((0, 0, 0), (0, a, 0))
points = [rs.CurveEndPoint(line)]
for i in range(1, 50):
line = rs.RotateObject(line, (0, 0, 0), 5, None, True)
rs.ExtendCurveLength(line, 0, 1, b)
if rs.CurveLength(line) < 0:
break
points.append(rs.CurveEndPoint(line))
