I’m going to work but are doing a test and need, make a 2 liter bottle with actual sizes
I have my volume only 916.41846 (+ / - 0.00013) cubic centimeters
Hi Saminsoo - You can try the script here:
http://wiki.mcneel.com/people/pascalgolay
for ‘SetObjectVolume’ It scales closed objects to meet the desired volume-- for a bottle, you’d want to do this for the inner volume only to the fill level , then scale other objects separately by the same factor if needed - there is provision for this in the script,
Thank you very much. But it could help with the calculation
Sorry, I don’t understand what you want to do, I guess- can you describe it in more detail?
sorry my English is not good. which is the mathematical formula to know these measures
Hi Saminsoo- for scaling in 3d, the scale factor
(desired volume/current volume) ^.333334 = scale factor
So:
(2000/916.41846 ) ^ .333334 = 1.297
For scaling in 2d
(desired volume/current volume) ^.5 = scale factor
for scaling in 1D
(desired volume/current volume) = scale factor
