I was wondering how to add a custom “tab” to the Properties - like below
Any documentation on that anywhere?
Thanks
Martin
Thanks
Martin
You may find this discussion useful - at that point in time there was not enough exposed in RhinoCommon to do this. C++ you may be more successful - look in RhinoSdkObjectPropertiesDialogPage.h
for more details.
Thanks - that helps.
Ooh wait… I was thinking wrong. I thought a tab not a properties tab. sorry for the confusion
Here you canfind an example how to add a tab
https://github.com/dalefugier/SampleCsPanel
also see:
You can extend the ObjectProperties page by overriding your plug-in’s PlugIn.ObjectPropertiesPages
virtual function and adding your page. Let me know if you need an example.
@dale, as said in an earlier discussion on this topic there seems to be problems when doing this from RhinoCommon - see http://mcneel.myjetbrains.com/youtrack/issue/RH-28555
Unfortunately I can’t access this Youtrack item to see if it has been solved in the mean time.
