I saw this video. https://vimeo.com/80169749 and results are totally different. Pls help how fix it or make ti better. ?
Best regards,
Peter
Best regards,
Peter
Do you have a model that is causing you trouble or is this a general question?
No. i only react on this video.
In general, you do get the same results between Neon and Brazil - or at least, pretty close. There are cases where there are some Brazil features that are not supported by Neon yet, and that will cause a difference.
I don’t know exactly what caused the difference in the case of the video, but I would need a model that shows a significant difference to be able to determine what the problem is.
