I’v created some macro commands, gave them a button etc…
Now i can’t see them in the toolbar manager so cannot back them up…
Any ideas ?
G.
If you have modified your default toolbar layout by adding buttons etc. I highly suggest that you:
- save it under another name, and
- periodically back up that file somewhere else
The reason for this is that in some circumstances, the default.rui (toolbar file) can be overwritten or corrupted.
To do this:
In Tools>Toolbar layout, highlight default in the upper right window and then use SaveAs from the file menu and give it another name.
The file itself is located here in a standard Windows install:
C:\Users\<username>\AppData\Roaming\McNeel\Rhinoceros\5.0\UI
Rhino will automatically create a backup file in the same directory, but I suggest you periodically also copy that out somewhere else as a second backup…
HTH, --Mitch
