Ghpython BUG?
This is ghpython components bug?Picking curve in rhino, out does not output, but can print
ghpython.gh (6.7 KB) no, out does not output, but can print
Hi 603419608
This is not a bug. For this to work, you need to copy all geometry to Grasshopper before you pass it out (with RhinoScriptSyntax or not). I am attaching an example.
If you can, I suggest that you do not use rs commands that block the UI with this method. Otherwise, this will really not feel Grasshopper-y and would make using your scripts much more error-prone for your users.
I hope this helps,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
ghpython-objects-by-layer.gh (7.1 KB)
Hi Giulio
Thank you very much for your help,I have another question,You say rs commands are rs.command () mean?
Thanks
Yes, I mean methods, functions or anything that blocks the User Interface (UI). For example, rs.GetObjects() blocks the Rhino UI.
Giulio
Giulio Piacentino
giulio@mcneel.com
Thank you very much
