Manolo
1
I want to know if a determined point is in Right, left, front, behind… of a brep
For example, in the next Image the green lines are in brep’s front face.
I think that if I calculate normal’s brep in the point I get (0, -1, 0) and I set that value to the front face
But with an irregular breps this method doesn’t work.
Do you know any form to determine easy the brep’s face given a point?
I’m working with c# and RhinoCommon
menno
(Menno Deij - van Rijswijk)
2
Use the ClosestPoint method that returns a omponent index. This index tells you which BrepFace is closest. Also you get u, v, normal and distance.
http://4.rhino3d.com/5/rhinocommon/html/M_Rhino_Geometry_Brep_ClosestPoint_1.htm
dale
(Dale Fugier)
3
A function like this might also be helpful:
static BrepFace BrepFaceFromPoint(Brep brep, Point3d testPoint)
BrepFace closest_face = null;
if (null != brep && testPoint.IsValid)
double closest_dist = RhinoMath.UnsetValue;
foreach (BrepFace face in brep.Faces)
double u, v;
if (face.ClosestPoint(testPoint, out u, out v))
Point3d face_point = face.PointAt(u, v);
double face_dist = face_point.DistanceTo(testPoint);
if (!RhinoMath.IsValidDouble(closest_dist) || face_dist < closest_dist)
closest_dist = face_dist;
closest_face = face;
return closest_face;
