I have uploaded a file through ITunes. I have synchronized. Yet it is not visible in Rhino.
What do you have to do to get Rhino to see the file?
I thought this would be an easy one.
I just used Google drive. Then you can log into your drive and download your model inside the rhino app.
The problem I have is that the files are loaded on the iPad (according to iTunes) but iRhino is not seeing them. Some apps (e.g. pages) have a second step you have to do on the iPad side to recognized what is loaded. I don’t see it for iRhino.
iTunes File Sharing is - in my opinion - less than obvious. I don’t use it, but it does work.
https://support.apple.com/en-us/HT201301
…might be helpful.
One caveat with iRhino 3D: the files will not show up until you restart iRhino 3D…and I mean actually close the application (not just background it).
For this reason, I suggest you use GoogleDrive or Dropbox.
I hope that helps,
-Dan
I don’t see anything loaded using iTunes, even when I completely restart.
You’re right. I see that now (IR-508). I’ll investigate more and fix it. Thanks for reporting it.
-Dan
Is this likely to be fixed in the near future?
I have not yet had a chance to address this bug. It is my top priority when I get a chance to work on iRhino 3D.
İ had same problem , for now only solution save file when its “shaded” view …
