I have many (10 000+) curves-closed polylines - image 1
I need to generate mesh for every single curve. I can do it one by one with MeshPatch command, but that would take eternity - image 2
When I use MeshPatch for all the curves, it generates a surface that is not ‘‘precise’’ enough. Possibly the command is intended to do so but I don’t know why - image 3
So It is not possible to MeshTrim the inside of curves i need. - image 4
this article says it has been fixed in 5.1 version. I have 5.1.20927.2230 and when I try to input multiple polylines I get ‘‘Cannot use these object, removing them from selection.’’ Single input works fine.
Could anyone with an up-to-date version confirm multiple input works?
