i am working on my bachelors project, and i have got a question i would enjoy to get an answer for
As you see on the image i have got a surface and projected a grid onto in, its basepoint is the center of the “stage”…
so now i would like to orient the seats with a lowpoly person included on every intersection point. Or float the seats along the line.
The problem with the usual floatalongsrf. is that the seats are not in 90° position, more like looking downwards on the floor … they should stay 90° but follow the surface…
The easiest would be to make a script that inserts the chair at each insertion point.
And orients it toward the center of the stage. Not a difficult task, I am working on it now, but now I have to put my daugher to bed first
(Just need to orient the chairs toward center to be done)
Ok, now she’s at sleep and here is the script working, with the Rhino file I tested on.
This will probably only work in Top View (And perspective view if Cplane = Top)
Edit: Oh, and the block has to be “facing” in the X direction.
And the block can be edited so all instances are updated of course. (rotate or add a person)
Regarding speed: I would always use a block for this, as I would be able to update them. Even swap out the entire chair, or change colors or redesign on the fly. Displaying a mesh is faster than nurbs, so sometimes they are just what I’d use. Also play with the mesh settings of the nurbs if you need more speed. Turning off Isocurves and lowering the custom mesh settings can make a sluggish scene much faster. Both to navigate and to render.
Now off to the couch for a beer with the wife. Cheers.
