Flamingo NXT 5.0
The background wallpaper renders fine with rhino render as current renderer. The wallpaper image does not render in NXT 5.0. with the same settings. Both Flamingo and Rhino are latest versions when I did a check update.
Any ideas?
@scottd, can you help?
The best way to do this is to set an environment background to Bitmap in the Flamingo Environment. Use the same image you are using for the wallpaper. You can get them to match.
Thanks Scott. Works. Rhino support is great.
