If this is for rendering, offset the inner surface of the glass be 0.01mm and use that as the fluid, tis way you donât get clashes when rendering.
Regarding volume:
ExtractSrf command to get the inside face of the glass.
Cap command to cap the shape.
Check the volume
Front view draw a horizontal line that bisects about 10mm (or whatever measurement) from the top of the fluid/volume and use the command WireCut.
Keep chopping off bits of the volume until youâre close to 250ml.
Second approach.
As above, make the volume of the fluid but 3D Scale the volume until you have 250ml then redraw the sectional detail of the glass and revolve it.
This way youâve scaled the volume and size of the glass but your wall thickness remains the same.
Another approach: The command âHydrostaticsâ will calculate among other things the displaced volume of water, with whatever waterline elevation you specify (relative to the CPLane). The thing to remember is that the units will be whatever your design is drawn with, so when you use mm, the volume will be expressed in mm3. 250 ml will thus be expressed as 250000 mm3.
What I would do is extract or isolate the inner surface of your drinking glass solid, raise or lower it until the 250 ml filling mark that you desire is at 0 elevation, i.e. on the CPlane. Run âHydrostaticsâ, keep the waterline at â0â and read the displacement. If it needs adjustment, 3Dscale your object by using random points on the Cplane for the origin and scaling factor reference points. Read the displacement again and repeat as necessary.
A more scientific way is checking by which factor the volume of the contents is off, then use the third power root of that to calculate your 3D scaling factor.
No need with Hydrostatics command to move the object. Just specify the desired waterline Z coordinate in the input to Hydrostatics. Pick a waterline height, run Hydrostatics and look at the calculated volume. If the volume is too large run Hydrostatics again with a lower waterline. If the volume is too small run Hydrostatics again with a higher waterline height. Iterate until the volume is close enough to the target volume.
That will still be trial and error, which apparently the TS does not want. I knew about the waterline input field, but wanted an easy way of scaling the object with the high water mark remaining in the same relative height.
There is no good tool for this- but- do you want to scale the object to meet the 250 ml or do you want to say, lower the top surface while keeping the overall size and shape otherwise intact? The second one is harderâŚ
I have modelled it already and made it so the total water volume is 300ml, I now want to put a mark/indentation at the 250ml point. I donât want to rescale the model
The Blender software looks like it will do it for me but i have only just started with Rhino and seeing another program has already begun to give me a head ache
All I can suggest then is to make a plane through the volume and BooleanDifference it from the object - check the volume (Volume command) , Undo, adjust the plane, repeat until you get close enoughâŚâ
Actually, the best way to do this is with a spreadsheet.
For instance, I needed an accurate way to size round-bottom chemical reaction vessels so I wrote a spreadsheet where I input the desired volume and diameter. On the output side I get 1/2 the volume of the sphere used for the bottom, which the spreadsheet subtracts from the total desired and gives me the height of the corresponding cylinder required for the total volume.
Then itâs just a matter of drawing an Arc S-E-D, a Line up, Join, Offset to the outside by glass thickness, close the curve top and revolve. For liquid, you would offset the inside curve by, say .001, Revolve and Cap the planar top.
With some thought, you can pretty much size volumes accurately using math and solid primitives. If you need to do this a lot, itâs better to write a function. I imagine it could be done in GH and if I had experience in GH itâd be worth a shot.
@Frank and @2DCube : I find it amusing that both of you assume that the âdrinking glassâ mentioned by the topic starter is a revolved shape, he never said it wasâŚ
