Feature request for Rhino 6 - Orient on (poly)surface
Hi everybody.
As we know, “orient on surface” works on one surface at a time.
if possible, could you make it work on multiple surfaces/polysurface? that could make the workflow much easier.
I think it will even be nice to have “orient on multiple surfaces” which are not even close/joined to each other.
but that is the least important, the more important is that it would work for a polysurface.
Example for a polysurface:
Can’t get to the right side of the polysurface (as it is another joined surface) in the same command instance.
Best Regards,
Roy Zadok.
