I’d like to export just my layout as a dxf? Is this possible. When I export it now it sends the whole file… I just want the page i designed to export. Thanks
Have you tried “Export Selected…” from the file menu?
work-around to export both geometry in the layout and the detail: print to PDF, import in new Rhino, and export as dxf.
If I print a pdf from Rhino, and I have tried many pdf writers, I get no objects when I try to read it
I just tried this with a few simple shapes and it works (in the sense that it does what it is supposed to do).
Did you select Vector Output
under Output Type
in the Destination
part of the Print Setup
dialog?
