I believe there is no built-in way to export curvature values from points on the curvature graph. Is there a script available to do this?
What I am thinking of is a way to export, as csv or xls, curvature values measured at a set distance along the curve (e.g. every 1 cm) or with a given density (e.g. 10 per curve) on all the selected curves.
Dmitri
@Zemleroi,
What curvature information you are interested in ?
below is a quick python script which creates a two column *.txt file. First column is the measured point, second the curvature radius at the point measured. You might open the script in the python editor using _EditPythonScript
to change some settings, eg. dgits after decimal, file format etc. The seperator between the columns is just a space character. You can set the number of divisions per curve when running the script.
Since this works with multiple curves, the list of rows starts with “CurveID:” (1st column) and the ID in the 2nd column…
CurvatureAtPointsToTxt.py (2.0 KB)
c.
Hello Clement,
Thank you for your reply and the code! I was looking at extracting the radii of curvature and the centres of curvature (xyz).
Dmitri
@Zemleroi,
below is an updated script with a third column for the curvature center.
CurvatureAtPointsToTxt2.py (2.3 KB)
c.
