DimCurveLength seems to require an actual curve - seems like it would fit better into the Rhino workflow if you could use surface edges as well.
thanks,
-d
thanks,
-d
Also, it would seem that DimCurveLength results should correspond to the âNumber formatâ as well as "Precisionâ of the Dimension settings. IE, âNumber formatâ is set to "Fractionalâ, it should return a fraction (based on what your âPrecisionâ is set to. Currently DimCurveLength only returns a decimal. The other dimension tools return whatever format youâve specified in your settings.
-d
Both of these problems stem from the fact that DimCurveLength is not a real dimension object, but just a text annotation associated with an object property that has history so it updates. So it doesnât work on surface edges because they are not real âcurve objectsâ in the file - they donât have a GUID. Perhaps someday they will, but for now this is the case.
And, not being a real dimension object, it does not pay attention to your dimension styles either.
Hope this explains whatâs happening, --Mitch
I donât have access to WIP right now but - are people seeing this as now working?
Hello - it works in V7.
Oops, on Windows at least.
Does not work, here, on Mac V7.
It works on brep edges but not on extrusion edges.
https://mcneel.myjetbrains.com/youtrack/issue/RH-54140
