Use a change of basis transformation when you need to compute the transformation to change coordinates from one plane to another. For example, of you had coordinates based on a (construction) plane and you wanted them transformed into world coordinates, you’d create a Transform.ChangeBasis
transformation.
The change of basis transformation is not the same as the rotation transformation that rotates one orthonormal frame to another. The Orient3Pt command uses a rotation transformation.
