Create surface from edge
Hi there,
It looks simple, newbie, but I can’t find anywhere the command to create a simple surface from edges (polylines or lines closed together).
Best regards,
Hi David- it depends on what the curves are like but-
EdgeSrf for up to four separate curves forming a closed loop.
PlanarSrf for any number of curves forming a closed planar loop
NetworkSrf for four edge curves plus, optionally, some interior curves in a grid-like arrangement (See help for details)
Patch (see Help)
Sweep2 could combine two rails and two shape curves,
Thank a lot for your patience, Pascal.
Indeed, I got confused I guess with the “curve” appellation. Even if Rhino is quite similar to Sketchup/Autocad, they are all working a bit different in some way.
Thank you again,
Best regards,
David
