Hi.
I am trying to create a mesh box in Rhinoscript, but I don’t know how to do it yet. Any suggestion?
Thanks in advance.
Hi.
Thanks in advance.
The rhinoscript help sample for AddMesh() illustrates adding a mesh box…
HTH, --Mitch
Edit: actually, sorry, the help example does not add a box. Following is Python - Rhinoscriptsyntax for adding a mesh box:
vertices = []
vertices.append((0.0,0.0,0.0))
vertices.append((5.0, 0.0, 0.0))
vertices.append((5.0, 5.0, 0.0))
vertices.append((0.0, 5.0, 0.0))
vertices.append((0.0, 0.0, 5.0))
vertices.append((5.0, 0.0, 5.0))
vertices.append((5.0, 5.0, 5.0))
vertices.append((0.0, 5.0, 5.0))
faceVertices = []
faceVertices.append((0,1,2,3))
faceVertices.append((0,1,5,4))
faceVertices.append((1,2,6,5))
faceVertices.append((2,3,7,6))
faceVertices.append((3,0,4,7))
faceVertices.append((4,5,6,7))
mesh=rs.AddMesh( vertices, faceVertices )
#if you want the edges to look sharp
rs.UnweldMesh(mesh, 10, True)
and here is the (vb) Rhinoscript version:
Option Explicit
Call TestAddMeshBox()
Sub TestAddMeshBox()
Dim arrVertices(7)
arrVertices(0) = Array(0.0, 0.0, 0.0)
arrVertices(1) = Array(5.0, 0.0, 0.0)
arrVertices(2) = Array(5.0, 5.0, 0.0)
arrVertices(3) = Array(0.0, 5.0, 0.0)
arrVertices(4) = Array(0.0, 0.0, 5.0)
arrVertices(5) = Array(5.0, 0.0, 5.0)
arrVertices(6) = Array(5.0, 5.0, 5.0)
arrVertices(7) = Array(0.0, 5.0, 5.0)
Dim arrFaceVertices(5)
arrFaceVertices(0) = Array(0, 1, 2, 3)
arrFaceVertices(1) = Array(0, 1, 5, 4)
arrFaceVertices(2) = Array(1, 2, 6, 5)
arrFaceVertices(3) = Array(2, 3, 7, 6)
arrFaceVertices(4) = Array(3, 0, 4, 7)
arrFaceVertices(5) = Array(4, 5, 6, 7)
Dim strMesh
strMesh = Rhino.AddMesh(arrVertices, arrFaceVertices)
'if you want the edges to look sharp '
Call Rhino.UnweldMesh(strMesh, 10, True)
End Sub
Thank you so much
