Cplane to World
Could some one tell me why this isn’t working. So I have a custom cplane that aligns with an object and would like to transform that object to the world xy plane. So I used the xformChangeBase() to get a transform matrix then try to input that int the transformObjects()
Objs = rs.GetObjects('Select Objects')
Cplane = rs.ViewCPlane()
TransM = rs.XformChangeBasis(Cplane,rs.WorldXYPlane())
TransObj = rs.TransformObjects(Objs,TransM,True)
Try to change this line:
to this:
TransM = rs.XformChangeBasis(rs.WorldXYPlane(), Cplane)
c.
Awesome. Worked.
Huh I thought the initial plane would be the “from” plane and the final plane would be the “to” plane. Bad assumption.
Yes, it is a bit confusing but correct.
rs.XformCPlaneToWorld() and rs.XformWorldToCPlane()
behave similar, we just need to swap both brain halves to get used to it. :wink:
c.
Yes.
Thanks again for the help. Was finally able to get my BlockFromCplane script up and going.
