I have a command where I would like to add an additional OptionEnumList based on the selection of an element while the command is running. If a user selects a specific element in the OptionEnumList I would like to then add an additional OptionEnumList for that choice.
var go = new GetObject();
for (;;)
go.ClearCommandOptions();
// Add command options here
go.Get();
// Process command options and continue here
break;
Is the a way to call ClearCommandOptions() on a specific option rather than all of them?
I’m looking to update one of the options after the user clicks each time but the remaining options should stay the same unless explicitly changed. I’ve got it working by saving out the other values to variables then reassigning them after I’ve called the ClearCommandOptions().
Seems like a lot of work to clear all options and re-instate all but one. I’m hoping I can simply clear the one that I want to update?
See code below. I’m wanting to add other options to the code below that would not be updated after the user clicks.
import Rhino as rh
import scriptcontext
rhdoc = scriptcontext.doc
def PlaceDots():
num = 0
direction = True
gp = rh.Input.Custom.GetPoint()
while True:
intNum = rh.Input.Custom.OptionInteger(num)
boolDirection = rh.Input.Custom.OptionToggle(direction, "Decrease", "Increase")
gp.SetCommandPrompt("Select coordinates for dot")
gp.AddOptionInteger("DotText", intNum, "Enter number for text dot to display")
gp.AddOptionToggle("NextNumber", boolDirection)
rc = gp.Get()
num = intNum.CurrentValue
direction = boolDirection.CurrentValue
#print num, direction
if rc == rh.Input.GetResult.Point:
if -9 <= num <= 9:
strNum = '0' + str(num)
else:
strNum = str(num)
td = rh.Geometry.TextDot(strNum, gp.Point())
rhdoc.Objects.AddTextDot(td)
rhdoc.Views.Redraw()
if boolDirection.CurrentValue == True:
num += 1
else:
num -= 1
gp.ClearCommandOptions()
continue
elif rc == rh.Input.GetResult.NoResult:
break
elif rc == rh.Input.GetResult.Option:
continue
break
if __name__ == "__main__":
PlaceDots()
Unfortunately, no this is not possible. The way you have done it is what we also do: clear all options and rebuild all options with the settings as they are changed by the user.
