Hi list,
I have a problem with blending in a composite material for Rhino render.
With low percentage blend the composite material becomes black. But with 0% on the blended materials, the base material is normal.
With a “Blend material” this works fine, but with “composite materials” not.
I try to blend gold, silver, copper and aluminum in one material.
Found the solution: The color of the base material has to be black, so it eat all light.
And you have to Add the materials. Blend does not works. Becomes black.
