Is it possible to set color settings on layers by CMYK rather than RGB and HSV?
Thanks,
Michael Deimen
Thanks,
Michael Deimen
Hi Michael- no, currently the color picker is what you see, no other options available. It is probably possible, assuming you know the cmyk numbers, to make a script that converts, but you would not be using an interactive cmyk color picker, just telling the thing what the numbers are- does that seem useful?
Hi Pascal,
It might if I had any idea how to write a “script”, but I’ve never even tried such a thing. Unless you can provide a tutorial, I’ll just have to live without.
Thanks for the quick response,
Michael Deimen
Hi Michael - I think I can make the script if that workflow (i.e. you already know the cmyk numbers) will work for you.
Hi Pascal,
The offer is much appreciated. What I need is a script that allows me to plug in different CMYK numbers. I have a range of color settings I’d like to employ. Is that possible with a script or do I need to write a unique script for every color setting? If so perhaps you can give me the low-down on how to write the script and I can just keep recreating it.
Best,
Michael D.
Hi Michael - one script should do it- can you post a range of numbers as you’ll want to enter them, so I can make sure to test the right thing?
Hi Pascal,
I’ll send you something tomorrow morning once I’m back at work. Thanks again for the help!
Best, Michael Deimen812-630-2165 Ph
Sent: Monday, November 24, 2014 6:05 PM
Subject: [McNeel Forum] [Rhino for Windows] Color settings on layers
November 24Hi Michael - one script should do it- can you post a range of numbers as you’ll want to enter them, so I can make sure to test the right thing?-PascalTo respond, reply to this email or visit http://discourse.mcneel.com/t/color-settings-on-layers/14292/6 in your browser.
November 24Hi Pascal,The offer is much appreciated. What I need is a script that allows me to plug in different CMYK numbers. I have a range of color settings I’d like to employ. Is that possible with a script or do I need to write a unique script for every color setting? If so perhaps you can give me the low-down on how to write the script and I can just keep recreating it. Best,
Michael D.
Hi Pascal,
The following CMYK combinations should serve as a good test bed for the script:
C-12 M-49 Y-39 K-0
C-15 M-100 Y-72 K-40
C-99 M-38 Y-20 K-24
C-60 M-70 Y-18 K-2
C-34 M-54 Y-73 K-0
C-5 M-17 Y-33 K-0
C-62 M-40 Y-18 K-0
C-73 M-38 Y-79 K-10
Thanks for the help,
Michael Deimen
Hi Michael - there are different ways to express the values … it looks to me like these are in a range of 0-100, correct, not 0-255? I’ll make the thing ask for a layer and then the color values- we’ll try that first.
@mdeimen, try this one and see how it works - Unzip, save, then then drag and drop the rvb file onto an open Rhino window to add the alias
CMYKLayerColor
this will work much like a regular command. Hmm - I’ll check this against V4 - it should work but I’ll make sure in a bit here. Yep, seems to work in V4, assuming I am guessing right about how the CMYK numbers should be interpreted.
CMYKLayers.zip (712 Bytes)
Hi Pascal,
Yes you are indeed correct. Zero to 100 seems to be the range for each color concentration. I’ll give what you’ve sent a try and let you know if it works.
Best,
mD
Hi Pascal,
I’m not sure what you meant by “add the alias.” I did the drag and drop. The command record came up with:
"Command: _-LoadScript
Script file to load ( List ): “C:\Users\deimenml\Desktop\CMYK Script from Pascal\CMYKLayers.rvb”
What should I be seeing now and where should I see it?
mD
Hi Pascal,
The following was the result of the drag and drop…
Script file to load ( List ): "C:\Users\deimenml\Desktop\CMYK Script from Pascal\CMYKLayers.rvb"
Command: _Save
Error replacing backup file “H:\Core Projects\Glass Whiteboards\Rhino\Glass Marker Board_11_24_14.3dmbak” with original file “H:\Core Projects\Glass Whiteboards\Rhino\Glass Marker Board_11_24_14.3dm” and original file “H:\Core Projects\Glass Whiteboards\Rhino\Glass Marker Board_11_24_14.3dm” with temp file "H:\Core Projects\Glass Whiteboards\Rhino\RHI6579.tmp"
Replace file function failed with error code 0.
Error writing file H:\Core Projects\Glass Whiteboards\Rhino\Glass Marker Board_11_24_14.3dm
Unable to save file as H:\Core Projects\Glass Whiteboards\Rhino\Glass Marker Board_11_24_14.3dm
Your thoughts?
Hmmm - the script does nothing with save… but typing in CMYKLayerColor
should autocomplete and run like a command… does that work?
It Works!!! Thanks Pascal, much appreciated.
Hi Pascal ! Can you upload the script again !? Thank you
