Clipping plane view slow
if:
  • the camera is on the clipped side of the plane navigation is slower
  • and “advanced GPU lighting” is turned OFF.
pretty strange as usually not using Advanced GPU gives me better speed on complex models, but as soon as a clipping plane is involved rotating the view is very sluggish… lagging behind the mouse cursor. a bit disturbing, because one needs to adopt display modes.
using latest rhino 5 sr and nvidia 361.43 on titan X
cheers
daniel
I’m not seeing this here with a few models I’ve tried. Same driver and a Titan black. Any chance you can upload a model to www.rhino3d.com/upload ? It’ll go to tech@mcneel.com by default which is fine, just say for Brian J and reference this forum thread.
The default Shaded mode is what I was using too which has adv GPU disabled. At a guess, this might have to do with the specific geometry or other display mode settings. Thanks for reporting.
Hi Brian,
I just uploaded a small file which already shows the problem, at least here on my machine.
To correct my last post a little, viewport rotation is in fact almost fluent if I look along the plane (so that it is hardly visible); once the cam gets more view of the clipping plane it gets a lot slower.
all only if advanced gpu lighting is turned off.
I know it is your policy anyway but please treat the file confidential .
thanks!
daniel
Thanks Daniel!
I replied via the support email… and filed a confidential bug report as I could reproduce it after rotating the clipping plane.
Hi Brian,
thanks for the update
glad I could help!
cheers,
d.
RH-32897 is fixed in the latest WIP
