The box in pictures is closed extrusion.
Anti-aliasing is never off until clipping plane is dropped in.
Also, clipping planes do not clip off dimensions and hatches properly and allow box selection of clipped objects (major no-no).
Fills for solids aren’t rendered.
brian
(Brian Gillespie)
July 27, 2016, 11:37pm
2
Thanks for reporting these problems.
I’ve logged http://mcneel.myjetbrains.com/youtrack/issue/RH-34987 about the clipping of text, and http://mcneel.myjetbrains.com/youtrack/issue/RH-34988 for the anti-aliasing problem.
I can’t reproduce the problem of the solid not filling, even with the same Shaded mode settings that you showed in your example. Can you please attach the model for me to look at?
This is from my work computer. Shaded display mode is default.
Untitled.3dm (39.1 KB)
Here’s the same thing in 5 (custom color settings though)
wim
(Wim Dekeyser)
July 28, 2016, 7:24pm
4
FWIW, solids never fill when clipped. This is not model-dependent and happens in all my display modes.
@dale , I just now saw that issue RH-29592 is on the ‘fixed’ list and as such I haven’t thought about commenting functionality lately.
In the latest RH6 WIP, when my clipping planes are on a layer that is off, the objects are not capped. When I turn the layer on, the objects become capped. They should be capped also when the layer is off.
http://mcneel.myjetbrains.com/youtrack/issue/RH-33562
brian
(Brian Gillespie)
July 29, 2016, 6:04pm
6
Looks like the clipping plane display bug was reported a couple different
times, and will be fixed in next week’s WIP:
http://mcneel.myjetbrains.com/youtrack/issue/RH-34713
