I am fairly new to flamingo, I hope this is an easy fix, I am under time pressures.
I created an animation with bongo, some stuff dropping in from the top of the frame into an assembly. Rendering in 720p, 50 passes per frame, using a groundplane with a flamingo brushed aluminum material applied to it. I have the setting reflect visible background checked, using a solid black background. Also using the standard light, set on studio lighting, with no extra lighting added to the scene.
The machine is a HP Z840, with a quadro 5200 graphics card.
The animation took about 20 hours to render, and to my dismay, at seemingly random intervals a frame appears in which the overall brightness is quite different than the others, much brighter, leading to unusable results.There are slight differences in the way flat surfaces are lit as well, they sort of gently flicker. Also, I tried to re-render the offending frames, and again, to my dismay, it seems that every time I quit rhino and re-open the file, I get slightly different results, enough to be noticeable.
Does anyone have any suggestions of what I might be doing wrong?
