I think that once you give the mainview the viewmodel, all nested controls inherit the DataContext of the main view.
Yes, Thank you soo much. Itâs okey now
I am also sorry for opening this once again, but I think that I got a similiar issue.
I have an UI that works pretty good in a plain WPF-Application.
Now I want to implement that in my Rhino Plug In and I get that error
I just added the App.xaml from the WPF-Application.
That is already a thing I am not quite sure about if that is possible.
Any suggestions would be very much appreciated!
As far as I know, you have to change your âwindowsâ to âusercontrolâ and dont touch app.xml.
If it is your first wpf plugin, its better to take a look at this sample:
Thanks, for the reply.
Ok, I wonât experiment with the App.xaml
I worked my way through the sample and there they also used a Window (at least in the WpfDialog)
In UserControl there is also no way to set the DataContext like this:
<Window.Resources>
<DataTemplate x:Name="redViewTemplate" DataType="{x:Type viewModel:RedViewModel}">
<view:RedView DataContext="{Binding}"/>
</DataTemplate>
</Window.Resources>
Or do you know another way to set the data context?
I donât get the error that the ViewModel does not exist in the namespace, it surely does âŚ
Its common to set the Data Context in a Windowsâs Code Behind.
The window constructor in code behind
public MainWindow(IMainViewModel mainViewModel)
this.DataContext = mainViewModel;
InitializeComponent();
Rhino Command
//Create Main WindowViewModel
var mainViewModel = new MainViewModel();
//Create Main Window with mainViewModel
var mainWindow = new MainWindow(mainViewModel);
//Create Helper to attach Rhino window(IWin32Window) as owner of Main Window(wpf)
WindowInteropHelper helper = new WindowInteropHelper(mainWindow);
helper.Owner = RhinoWinApp.MainWindow.Handle;
//Open Window
mainWindow.Show();
