Just installed windows 10 on a new iMac and the only way it will operate there is if the ‘automatic software updates’ is turned off because Apple isn’t compatible with the latest v10 drivers. However, Flamingo nXT won’t load unless the 'atuo updates is turned on. Any suggestions?
Are you running Windows in using Fusion or VMWare?
What error do you get when you try and install?
Thanks for replying - problem solved.
