Hi epiphany -
I am not finding this to be the case here so far. I set Print color to two different lines to two different custom color, the layer color is a third color. With PrintDisplay on and showing Print colors, if I select these lines I can set the print color to Custom - shows the two colors - or Layer, shows the layer color. Is that what is not working for you, or is that not a good test of the thing you see?
