I’m trying to create a text object and chamfer it, but not by a little, but completely - at an angle of 45°.
I create a text object: (its height is 10mm)
Then I run ChamferEdge, and select 2mm as chamfer distance. I get this mess:
But I’d like to get something that looks like this in 2D:
Is there a way to achieve this effect of “letters in stone” in 3D? I don’t want to simulate it. I also don’t want to do them by hand, obviously.
Thank you for any help.
scottd
(Scott Davidson)
2
I find that this is not simply make a solid then chamfer. Here is a video on using a more manual method:
The steps are
- Create the curves
- Explode
- Extrude Tapered
- Extend Surfaces
- Trim
- Join
This should work well in more cases.
Thanks a million for your time and effort.
I hope someone can come up with an idea that doesn’t involve manual work.
@Helvetosaur @pascal
Hello
Now it’s 2020. Is there a “Script” to make the “Belevel Curve Text” text effect faster?
Extrude up to 45 degrees and enter the desired height
Lena1
(Lena)
5
Hello, can i ask how you did this? I know its an old post, but i would like to know how you proceeded ith the bevel curved text. Thank you
