Array between with dynamic preview
The script below allows you to make an array of curves or poly(surfaces) linearly. Where ArrayLinear will make an array where you set the distance between items, this script will distribute the arrayed objects over the distance you pick. Made this mainly for learning purposes, but might be useful for some. Should work on Windows and Mac.
This script allows you array curves, surfaces and polysurfaces, from object
boundingbox center to a picked point, where the new objects will get distributed
between center and picked point. You will see a dynamic preview and can
change the amount while the preview updates.
* script written by Gijs de Zwart *
* www.studiogijs.nl               *
* April, 2016                     *
import Rhino
from System.Drawing import Color
import scriptcontext as sc
def ArrayBetween():
    def OnDynamicDraw(sender, e):
        pts=[]
        count=optInt.CurrentValue
        line = Rhino.Geometry.Line(center, e.CurrentPoint)
        curve=line.ToNurbsCurve()
        params=curve.DivideByCount(count-1,True)
        for param in params:
            pts.append(line.PointAt(param))
        vec = e.CurrentPoint - center
        length = vec.Length
        dist=length/(count-1)
        vec.Unitize()
        for i in range(1,count):
            translate = vec * i * dist
            xf = Rhino.Geometry.Transform.Translation(translate)
            newobj=obj.Duplicate()
            newobj.Transform(xf)
            if obj.ObjectType==Rhino.DocObjects.ObjectType.Curve:
                e.Display.DrawCurve(newobj, Color.LightCyan, 2)
            if obj.ObjectType==Rhino.DocObjects.ObjectType.Brep:
                e.Display.DrawBrepWires(newobj, Color.LightCyan)
        e.Display.DrawLine(line, Color.Blue, 2)
    def getPoint():
        while True:
            result = gp.Get()
            if result == Rhino.Input.GetResult.Point:
                line = Rhino.Geometry.Line(center, gp.Point())
                pts=[]
                vec = gp.Point() - center
                length = vec.Length
                vec.Unitize()
                        sc.doc.Objects.AddCurve(newobj)
                        sc.doc.Objects.AddBrep(newobj)
                sc.doc.Views.Redraw()
            elif result == Rhino.Input.GetResult.Option:
                #go back to point selection mode
                getPoint()
            break
    docobj = rs.GetObject("select object to array", 28)
    if rs.IsCurve(docobj):
        obj=rs.coercecurve(docobj)
    if rs.IsBrep(docobj):
        obj=rs.coercebrep(docobj)
    if not obj: return
    plane=Rhino.Geometry.Plane.WorldXY
    bb=obj.GetBoundingBox(plane)
    if bb==None:
        print "can't calculate boundingbox"
        return
    center = bb.Center
    minimum = bb.Min
    center[2]=minimum[2]
    gp=Rhino.Input.Custom.GetPoint()
    gp.SetCommandPrompt("point to array to / distance")
    optInt=Rhino.Input.Custom.OptionInteger(3,3,999)
    gp.AddOptionInteger("Count",optInt)
    gp.SetBasePoint(center, False)
    gp.DynamicDraw += OnDynamicDraw
    getPoint()
if( __name__ == "__main__" ):
    ArrayBetween()
thank you!
Thanks you for sharing this script
Vittorio
Nice !
Thanks.
glad you like it,
attached is an updated version: now you can change basepoint
Still assumes working in world xy plane:
boundingbox center or corners to a picked point, where the new objects will get
distributed between center or corner and picked point. You will see a dynamic preview
and can change the amount while the preview updates.
* April, 2016                     *
import Rhino
def ArrayBetween():
        i=optBasePoint[0]
        pts=[]
        if i==0:#center
            basept.X = center.X
            basept.Y = center.Y
        if i==1:#lowerleft
            basept.X = center.X-width/2
            basept.Y = center.Y-depth/2
        if i==2:#upperleft
            basept.Y = center.Y+depth/2
        if i==3:#lowerright
            basept.X = center.X+width/2
        if i==4:#upperright
        vec = e.CurrentPoint - basept
        gp.SetBasePoint(basept, False)
        line = Rhino.Geometry.Line(basept, e.CurrentPoint)
        length = vec.Length
        vec.Unitize()
    def getPoint():
        while True:
            result = gp.Get()
                pts=[]
                vec = gp.Point() - basept
                length = vec.Length
                vec.Unitize()
                optionindex = gp.Option().CurrentListOptionIndex
                optBasePoint[0]=optionindex
                getPoint()
            break
    if not obj: return
    if bb==None:
        return
    center = bb.Center
    basept = bb.Center
    minimum = bb.Min
    maximum = bb.Max
    center.Z=minimum.Z
    width = maximum.X-minimum.X
    depth = maximum.Y-minimum.Y
    basepoints=["center", "lower_left","upper_left","lower_right","upper_right"]
    gp.AddOptionList("basepoint", basepoints, 0)
    optBasePoint=[0]#equal to index 0 of basepoints option
    getPoint()
    ArrayBetween()
Nice work Gijs!
Just a reminder that the Rhino WIP has a new Distribute command.
thanks,
didn’t know about distribute. nice addition :slight_smile:
How do I import this scrpit into Rhino?
Is there any possibilitie that when you array objects, it number remains dynamic?
You can change it after?
easiest way is to make a button for it (you can use the attached icon) and make a reference to the script on your harddrive. For example, if you save your scripts in c:\scripts\ Then you can place the following in the button:
noecho -RunPythonScript "c:\scripts\arraybetween.py"
array_between
With this simple script, no. I could improve it though, but it’s not high on my priority list. I made the script long time ago to learn working with display conduits.
So since Rhino still doesn’t have this option in its array toolbar, I had to go searching on this forum.
Weirdly, “distribute” asks me to select three objects, but I just want to array one, so has the command changed in the last 6 years?
Thank you for making the script, it works great! But why did you choose a few hard-coded basepoints instead of just letting the user pick their own start and end points?
I think what Dale was referring to at the time was the fact that you can ArrayLinear your objects. Move the last one in the correct place and then distribute the other objects equally in between the first and the last. That’s how I usually solve this problem.
Distribute doesn’t create new geometry, it just spaces objects an equal distance apart.
That’s funny. So after 6 years, something this simple still requires a user made script? Well, at least users can do scripts to fill gaps in functionality. :laughing:
That was 6 years ago, I don’t have a good explanation other than:
Can you post an example where a different basepoint would get you the result you want?
Well, sure but consider this instead: The built-in ArrayLinear asks you for a “first reference point” and a “second reference point” and interactively draws a preview while you are selecting the second one. That’s actually great UX and a good target to make it intuitive for new script users (but I understand that it was outside of the scope of the excercise). :slight_smile:
