Is there a way to also affect the “name” attribute for this newly created mesh?
mesh = Rhino.Geometry.Mesh()
mesh.Vertices.Add(0.0,0.0,0.0)
mesh.Vertices.Add(xdim, 0.0, 0.0)
mesh.Vertices.Add(xdim, ydim, 0.0)
mesh.Vertices.Add(0.0, ydim, 0.0)
mesh.Vertices.Add(0.0, 0.0, zdim)
mesh.Vertices.Add(xdim, 0.0, zdim)
mesh.Vertices.Add(xdim, ydim, zdim)
mesh.Vertices.Add(0.0, ydim, zdim)
mesh.Faces.AddFace(0,1,2,3)
mesh.Faces.AddFace(0,1,5,4)
mesh.Faces.AddFace(1,2,6,5)
mesh.Faces.AddFace(2,3,7,6)
mesh.Faces.AddFace(3,0,4,7)
mesh.Faces.AddFace(4,5,6,7)
mesh.Normals.ComputeNormals()
mesh.Compact()
menno
(Menno Deij - van Rijswijk)
July 11, 2014, 3:27pm
2
You can set a name on the ObjectAttributes when you add the mesh to the document.
I tried :
attributes = Rhino.DocObjects.ObjectAttributes()
Rhino.DocObjects.Tables.AddMesh(mesh, attributes)
Opposed to the
doc.Objects.AddMesh(mesh) from scriptcontext
And had two problems :
Message: attribute ‘AddMesh’ of ‘namespace#’ object is read-only
And setting the Mesh name in objectattributes
http://4.rhino3d.com/5/rhinocommon/html/P_Rhino_DocObjects_ObjectAttributes_Name.htm
dale
(Dale Fugier)
July 11, 2014, 4:29pm
4
Try this:
/// C#
double xdim = 15.0;
double ydim = 10.0;
double zdim = 5.0;
Rhino.Geometry.Mesh mesh = new Rhino.Geometry.Mesh();
mesh.Vertices.Add(0.0, 0.0, 0.0);
mesh.Vertices.Add(xdim, 0.0, 0.0);
mesh.Vertices.Add(xdim, ydim, 0.0);
mesh.Vertices.Add(0.0, ydim, 0.0);
mesh.Vertices.Add(0.0, 0.0, zdim);
mesh.Vertices.Add(xdim, 0.0, zdim);
mesh.Vertices.Add(xdim, ydim, zdim);
mesh.Vertices.Add(0.0, ydim, zdim);
mesh.Faces.AddFace(0, 1, 2, 3);
mesh.Faces.AddFace(0, 1, 5, 4);
mesh.Faces.AddFace(1, 2, 6, 5);
mesh.Faces.AddFace(2, 3, 7, 6);
mesh.Faces.AddFace(3, 0, 4, 7);
mesh.Faces.AddFace(4, 5, 6, 7);
mesh.Normals.ComputeNormals();
mesh.Compact();
Rhino.DocObjects.ObjectAttributes attribs = doc.CreateDefaultAttributes();
attribs.Name = "Sample Mesh";
doc.Objects.AddMesh(mesh, attribs);
doc.Views.Redraw();
return Result.Success;
That worked great, for both c# and translating it to python.
So does Rhino.DocObjects.Tables.ObjectTable.AddMesh(mesh)
actually do anything?
it seems to want two member variables
but does it work the same way as : doc.Objects.AddMesh(mesh, attribs);
… I guess its a more general question
Rhino.DocObjects.Tables.ViewTable.Redraw()
since that also wants an arguement
I guess I am missing something fundamentally about using Rhino.DocObjects.
stevebaer
(Steve Baer)
July 11, 2014, 5:13pm
6
This is the definition of a function. You need to call that function with an instance of the RhinoDoc class. This is where ‘doc’ comes into play.
@stevebaer … love the blog
… that makes sense
Can you access an instance of RhinoDoc in python from Rhino.DocObjects ?
stevebaer
(Steve Baer)
July 11, 2014, 5:49pm
8
in python you access the doc through scriptcontext.
import scriptcontext
scriptcontext.doc.Objects.AddMesh(mesh)
Cool, thanks.
I noticed you can also do something like this:
Rhino.DocObjects.Tables.ObjectTable.AddMesh(scriptcontext.doc.Objects,mesh, attribs)
So scriptcontext.doc is the only way to access the current ObjectTable and ViewTable then I guess.
stevebaer
(Steve Baer)
July 11, 2014, 6:29pm
10
Yes, that is just different syntax for the same thing
That is the “correct” way to access these tables. There is a RhinoDoc.ActiveDoc function, but I would almost always recommend using scriptcontext.doc instead.
because the ActiveDoc can change right?
