Add parameter in command
I’ve created a command, and I need pass parameters.
I can create a new property in PlugInClass and get this property in the command, but I don’t like do it.
I call the command so
return (Rhino.RhinoApp.RunScript(“AgutImportDXF”, true));
So… how I can pass a parameter?
I’m using c# and rhinoCommon
Let’s say your command AgutImportDXF has two parameters (MyParam1 and MyParam2), one number and one toggle (Yes/No).
Then, you can script it like this:
return (Rhino.RhinoApp.RunScript("_-AgutImportDXF MyParam1=140 MyParam2=Yes _Enter", true));
Note the use of the -(dash) in front of the command, this is to set the command to scripted mode. Secondly, note the _ (underscore) in front of the command and the Enter command. This is to force English name of the command when Rhino is running in another language.
And…how I can get the parameters value inside the command class
in RunCommand function?
try
_doc = doc;
if (_plugin == null)
_plugin = new AgutCAM2PlugIn();
if (ImportarDXF())
return Result.Success;
else
return Result.Cancel;
catch
You looking for:
    string str = String.Empty;
    RhinoGet.GetString("Custom String", true, ref str);
    if str = 0
dont know if I typed that right but this way you can get a custom str. or integer.
I’m more into Vb.NET
Ok, It works but…
I run the script so:
Rhino.RhinoApp.RunScript("_-AgutImportDXF calibrado=10 _Enter", true);
If I use inside RunCommand method:
RhinoGet.GetString(“calibrado”, true, ref str);
the result in str is “calibrado = 10”
If I use
RhinoGet.GetInteger(string.Empty, true, ref _calibrado);
the result in _calibrado is 0 not 10
How I can use RhinoGet.GetInteger?
An integer is only a number so it cant get calibrado=.
Then you should do something like:
Ingeger int = 0
RhinoGet.GetInteger(“calibrado”, true, ref int );
Rhino.RhinoApp.RunScript("_-AgutImportDXF 10 _Enter", true);
It not works.
And if I want two parameters… how can I differentiate both? The first parameter in GetInteger is not referenced in RunScript
Please see this example on how to use GetOption with multiple command line options
Thanks menno.
I had not seen that example.
I can read the parameter so:
In RunCommand function
int _calibrado = 0;
OptionInteger optionInteger = new OptionInteger(0, 0, 1000);
GetObject go = new GetObject();
go.AddOptionInteger(“calibrado”, ref optionInteger);
RhinoGet.GetInteger(“calibrado”, true, ref _calibrado);
and calling RhinoScript
No, this is wrong. Don’t use RhinoGet.GetInteger, use go.Get(), just like in the example. Then you can use named parameter as I wrote earlier.
oki, thanks
