Would it be possible to write a python script that allows the user to INSTANTLY add an object to a block definition without going through block edit?
Hi Guido,
Find attached 2 scripts than can be drag-dropped over Rhino.
They need to remain in the location you dragged them from in order to keep functioning.
I did not test them for some time so see if it is of any use.
AddObjectsToBlock.rvb (1.5 KB)
ExtractObjectsFromBlock.rvb (1.7 KB)
DeleteObjectsFromBlock.rvb (2.1 KB)
Let me know when you have any issues.
@Pascal is there a wish item for this type of functionality already?
If not could it be added the hassle of the block-editor is often inefficient.
I remember having quite a speedup with these scripts for a project with a lot of āvolatileā blocks
HTH
_Willem
Thanks Willem!
Thatās pretty much the functionality I had imagined (and I definitely think this should be standard in Rhino! all the block editing functions and interfaces need an overhaul).
Great work!
-GM
Hi GM,
I was interested in something like this, but the rhinoscripts are no longer available for download.
Iāve tried in Python, but for some reason the block moves position when I add the new Geo.
import Rhino
import scriptcontext as sc
def AddToBlock():
objects = rs.GetObjects("Choose Objects to Add to Block", preselect=True)
if not objects: return
block = rs.GetObject("Choose Block to Add Object to", rs.filter.instance)
if not block: return
objref = rs.coercerhinoobject(block)
idef = objref.InstanceDefinition
idefIndex = idef.Index
#New Geo
newGeometry = []
newAttributes = []
for object in objects:
newGeometry.append(rs.coercegeometry(object))
ref = Rhino.DocObjects.ObjRef(object)
attr = ref.Object().Attributes
newAttributes.append(attr)
#Existing Block Geo
blockCopy = rs.CopyObject(block)
blockObjects = rs.ExplodeBlockInstance(blockCopy, explode_nested_instances=False)
for object in blockObjects:
InstanceDefinitionTable = sc.doc.ActiveDoc.InstanceDefinitions
InstanceDefinitionTable.ModifyGeometry(idefIndex, newGeometry, newAttributes)
rs.DeleteObjects(blockObjects)
sc.doc.Views.Redraw()
AddToBlock()
Hoping someone might have a solutionā¦ or the old rhinoscripts.
Cheers
AM
You could try the linked zip file which seems to have survived the current problems with attachments on this site
Cheers
G
That works beautifully,
Cheers
AM
I translated @Willemās rhinoscript to python. It seems to be working. Thanks Willem!
import Rhino
def AddToBlock():
rs.EnableRedraw(False)
blockName = rs.BlockInstanceName(block)
if rs.IsBlockReference(blockName):
print "Block is referenced from file; unable to add object(s)"
return
blnCopy = False
XformBlock = rs.BlockInstanceXform(block)
rs.TransformObjects(objects, rs.XformInverse(XformBlock), blnCopy)
objects.extend(rs.BlockObjects(blockName))
newGeometry = []
newAttributes = []
rs.DeleteObjects(objects)
rs.EnableRedraw(True)
AddToBlock()
Edit 1: RemoveFromBlock isnāt working as nicely as Willems so I will see what I can do to fix it
Edit 2: Fixed
And Remove from block:
import Rhino
def RemoveFromBlock():
block = rs.GetObject("Select Block to extract objects from", rs.filter.instance, preselect=True)
blockObjects = rs.BlockObjects(blockName)
blockInstanceObjects = rs.TransformObjects(blockObjects, XformBlock, True)
objs = rs.GetObjects("Select Objects to extract from Block", objects =blockInstanceObjects)
if not objs:
rs.DeleteObjects(blockInstanceObjects)
return
keep = [] #List to keep in block
delete = [] #list to delete from block and add to doc
for object in blockInstanceObjects:
if object in objs: delete.append(object)
else: keep.append(object)
print "Block is referenced from file; unable to modify block"
rs.DeleteObjects(keep)
return
rs.TransformObjects(keep, rs.XformInverse(XformBlock), False)
newGeometry = []
newAttributes = []
for object in keep:
RemoveFromBlock()
