Access Notes Outside of Rhino Instance
Hi Everyone,
I have written a script that places various information about the model into _Notes. I am looking to access this info, through a script, outside of a Rhino Instance. I noticed the information appears in Windows Explorer in a ReadOnly box under the PreviewImage. However, I do not know where to access this information; I can not find it when I right-click the file and go into the properties box. Does anyone have an idea on where this information is stored for me to access through python?
Thanks!
-Norsemen
If you use the Rhino3dIo toolkit
you can read the notes from a file using the function
Rhino.FileIO.File3dm.ReadNotes(string path);
This would be easiest if you are writing code in C# or VB.NET. For python, you would have to use IronPython since this is .NET code.
Still works great!
Thanks,
