I am trying to add sphere to a grid of points, but I can only seem to add one sphere rather than to the entire grid.
I am sure this is simple.
Thank you, Erik
color01 = [255,0,255]
color02 = [0,255,255]
color03 = [125,38,205]
#radius
rs.EnableRedraw(False)
for x in range (0,100,5):
for y in range(0,100,5):
pt = rs.AddPoint(x,y,0)
if x % 4 and y % 9 == 0:
rs.ObjectColor(pt, color01)
elif x % 3 == 0 or y % 6 == 0:
rs.ObjectColor(pt, color02)
else:
rs.ObjectColor(pt, color03)
rs.AddSphere(pt, .25)
rs.EnableRedraw()
You just need to indent your rs.AddSphere() so it’s at the same level of indentation as pt= currently is - right now it’s outside of your loop…
pt will be a GUID of a point object, as rs.AddPoint() adds a point object to the document. If you want that point, keep the line in, but otherwise you can just add the sphere:
rs.AddSphere([x,y,0], 0.25)
–Mitch
Great thanks Mitch that makes sense.
Now I’m trying to extend it a bit. but it says the guid cannot be converted to a plane. I thought points were planes esp when defined in the x and y axis
import random as rd
step = 4
for x in range (0,100,step):
for y in range(0,100,step):
cone = rs.AddCone(pt, .5, True)
sphere = rs.AddSphere(pt, .7)
rs.ObjectColor(sphere, color01)
rs.ObjectColor(sphere, color02)
else:
rs.ObjectColor(sphere, color03)
rs.EnableRedraw()
A GUID is not a point - it is a point OBJECT (one that you can actually see as a point in the document). If you are working with placing objects at points, you do not want to work with point objects added to the document, but rather 3D points that are defined simply by their x,y,z coordinates and are not added as point objects in the document. There’s absolutely no need to use AddPoint() to create points in the Rhino document if you don’t need them, and it will slow things down if you use a lot of them.
import random as rd
step = 4
# look at the following line, this creates a rhino/python 3D point
pt = rs.coerce3dpoint(x,y,0)
else:
Ok that makes sense. Creating the points was definitely slowing down my computation. rs.coerce3dpoint is handy.
Thanks for the help!
Erik
Actually, I am getting an error,
“Message: coerce3dpoint() takes at most 2 arguments (3 given)”
Sorry, my bad, keep forgetting you need to pass the coordinates as a list or tuple:
pt = rs.coerce3dpoint([x,y,0])
Cheers, --Mitch
Great. Thanks. I also found that
pt = (x,y,0)
works as well.
Thanks again.
