A history update question
1.Have two curve A,B. loft curve A , curve B . use rhino command “Loft”, enable history.
2.Modify curve A use my plug-in. The history not update.
3.But the history can update use rhino command “HistoryUpdate -a”.
@dale
Thanks!
Now is ok, use doc.object’s.replace()
Thanks every body.
@KelvinC @dale
@mdjcad asked me this question in a private message. I had him to check if “Update Children” has been disabled.
Update Children is enable
Can you provide some code to a simple test command that repeats this behavior?
@dale
Thank you.
I has been resolved.
@mdjcad I have been following this with interest, can you share how it was solved and what the problem was?
Can you speak Chinese? :sweat_smile:
能讲中文不?
@menno
你是怎么解决的? 能不能将你碰到问题的代码和解决过程贴上来。
