As per subject, _PrintDisplay when on does not render dots in their print color.
In addition, dot’s still print incorrectly as squares(pdf print)
-Willem
-Willem
Hi Willem- I see the display color part, but I do not see the rectangular dots with the masking not working in Print. It seems to me I have seen this in the past, but either we fixed something or… not.Probably related to video cards, I imagine. What card do you have?
thanks,
Hi Pascal,
The image is a capture from a PDF file, inside Rhino the display correct, however when I print Dots to a pdf this is how they show up. Is that not happening at your machine?
I’m using PDFcreator for PDF output.
Thanks
-Willem
I thought I fixed this. Are you using the SR6 release candidate?
Yes I think so:
Thanks
-Willem
This seems to be fixed for SR10. Font is still incorrect though.
Can you make a bugtrack issue for this so I don’t forget? Thanks
_PrintDisplay still not working for Dots for me. They remain in Display Color and do not show Print Color. When printing it seems to be correct though. So only within the Rhino Viewport. Running v5 SR12.
Hi Duncan- yeah, it is hard to tell from the bug track item but this appears to be fixed in V6 and not V5.
That is correct. The underlying technique for how dots are displayed / printed was rewritten in V6 and at that time the bug was fixed. This is not in V5, sorry.
Thanks for the update, good to know. So how soon is V6 upon us then? I can’t wait.
